Rocker box gasket
Rocker box gasket
Anyone have the part number for the rubber (rather than cork) gasket for a DX engine (1990 Scala), also number for the longer studs required?
Re: Rocker box gasket
Hi Jem
if you get it from VW it usually includes the studs
jf you give them a buzz they usually know which one it is.
Heritage -
https://www.vwheritage.com/shop/0261980 ... olf-jetta/
Heritage -
Danny
Many thanks, guys. Have now ordered from VW Heritage. I expect my engine block will rust when I cure the leak!!
