Parcel shelf clips
Don't know German? look here
Moderator: Scirocco Register
Derbyboy
Parcel shelf clips
Post by Derbyboy » Sun Nov 25, 2012 1:13 pm
Are the parcel shelf clips the same on clipper golf as the scirocco just found this pair on the bay
390474872036 item number
Re: Parcel shelf clips
Post by mark1gls » Mon Nov 26, 2012 11:26 am
That does look like them, not 100% sure but I think new ones from VW will be cheaper than the £7.92 they are charging for 2nd hand ones.
Might be worth a phone call to your local VW place to check first.
ryder
Post by ryder » Mon Nov 26, 2012 7:02 pm
got two of these clips from local scrappy, they are an exact fit
