As the title, does anyone know what the numbers are?
Part No. for EG and DX cams?
big nick
do I really want a carb'd valver? answers on a postcard...
Re: Part No. for EG and DX cams?
EG cam 049 109 101 N
DX cam same number, but in 1984 there was a revised G grind cam, 049 109 101 G
big nick
AMAZING!!
Thanks so much, I trawled through Google all day and couldn't find those numbers.. Now I can spin those 10milli nuts off the cam cover studs and and confirm in my own head that I don't already have a GTI cam, then I can go shopping for some speed parts
Is there much difference between the G and N grind cams? Its just a hunch but I reckon they have the same lift&duration but a different ramp angle to compensate for the differences in bore, stroke, rod ratio, valve area:displacement ratio and breathing between the two lumps..but I might have just made that up in my head without any proof...
I would guess the difference is that before 1984 the head uses solid shims and after 1984 hydrolic shims.
Just a guess.......
Just a guess.......
big nick
I had it in my head that the changeover from shimmed lifter to hydraulic lifter was in '86?
the DX2 had hydraulic lifters, at this stage it was still solid lifters
big nick
I pulled the cam cover off to have a nosey at the cam thats currently in there and the markings on it are;
"W" on 1, the VW/Audi symbol on 2, "049C" on 3 and "WTR" on 4..
Does this identify it as a certain part no or some particular grind? Is there a way I could find out the specs of the cam to compare it to the EG/DX jobbie I'm looking to throw in there as short term measure before the 16v goes in?
Sorry for all the questions but I have a slightly OCDish 'research geek'/'part-number whore' streak, just incase you hadn't noticed ":hehe:"
correct.big nick wrote:I had it in my head that the changeover from shimmed lifter to hydraulic lifter was in '86?
