Distributor number for a Scala(carb)
Don't know German? look here
Moderator: Scirocco Register
Beddo88
Post by Beddo88 » Thu Jul 05, 2012 11:57 pm
Hi,
I may need to swap my dizzy soon as I fear it may be causing my running issues, can anyone confirm what spec (part no.) of Dizzy I should have on a Scala (carb) EX engine?
It's a late 87 if that helps!! There are so many different numbers in googleland :(
Any help much appreciated!
Dan
