Looking for numbers or more importantly sizes ie. m10X70 of the the following bolts
All for mk1 16v application...
1. Two bolts that hold the front CUP type mount to the body. (mk1)
2. Single bolt that goes through the gearbox mount, (mk1) and also the two bolts that go through the top of the gearobx. (mk2 16v)
3. Three bolts that hold the Engine/Gearbox mount to the gearbox (two part mount) mk1
4. And the engine mount bolt. (mk1)
I'm on the brink of getting my engine back in and this is holding me up big time! Any help....very appreciated.
ENGINE MOUNT BOLTS
- Bonusrocco
Re: ENGINE MOUNT BOLTS
According to ETKA.....
N 010 254 14 - M10 x 25mm x2 with 411 395 169 - concave washer and 111 857 707 A - 30mm washer with 11.5 hole dia
N 010 472 11 - M10 x 85mm bolt and N 010 470 7 - M10 x 70mm bolt
Are you sure these aren't studs with nuts on? ETKA is unclear, but as best I can tell, it should be a 50mm M10 stud in the transmission housing, but if your transmission is from a mk2 golf, there seems to be a chance that there's nothing in the hole, and they're not threaded for a stud, in which case measuring a mk2 golf 'box I have, you need a 100mm bolt.
- Bonusrocco
- Bonusrocco
Actually I have another request
Engine to gearbox housing bolts...
So many plans, so little time
N 019 524 1 Those are the two bolts at the top of the bell housing, M12 x 55mm
N 902 992 01 That's the one that goes through the block and into the box near the diff, M12 x 62mm
N 044 760 1 This is the top bolt through the starter/ bellhousing/block/engine mount M10 x 135mm
N 044 742 1 This is the bottom bolt through the starter/bellhousing/block/engine mount M10 x 150mm
BTW, I can totally recommend getting a copy of ETKA! http://www.ebay.co.uk/itm/ETKA-7-3-EPC- ... 4d020a8e41
