Part Numbers request!
Don't know German? look here
Bonusrocco
Post by Bonusrocco »
Hi,
I'm trying to find some part numbers if anyone can help! VAGCat is just dead for me...
1. Main gearbox to engine bolts - mk2/3 golf/scir/corr 16v
2. Metal clips with hole in to retain brake flexi-hoses (little c shaped things) on mk1 chassis.
Thank thank thank you
So many plans, so little time
Blueshark
Re: Part Numbers request!
Post by Blueshark »
Bonusrocco wrote:Hi,
If you mean the clip where the hose goes through it will be 803611715
dozzum
Post by dozzum »
I think the bolts your after are
N 101 028 03 Hexagonal Head Bolt BM8X98-PC Quantity 3 manual gearbox
That's under 1991 Golf, Transmission securing parts 1.6-2ltr
Although 3 bolts doesn't seem right to me?
Post by mr.brown »
dozzum wrote: Although 3 bolts doesn't seem right to me?
3 bolts is correct. Two at the top and one near the inner CV. The other two bolts are the starter motor bolts. And there are are a few smaller ones for the cover(s) depending on what box/engine you have.
Brake C clip from GSF - http://www.ebay.co.uk/itm/Front-Rear-Br ... 0662105397 - I can't imagine a genuine VW one would be any different in quality :good:
MJK 24
Post by MJK 24 »
Bit of a difference in price though:
GSF £2.99 each
VW £0.11 each on my bill from last week.
There's six on the car. Do you want to pay £0.66 or £17.94?!
ALWAYS check with the dealer first!
Bonusrocco
Thanks for the help chaps :chill:
