MK2 Rear view mirror
NEW section - if you're having a mare with Vagcat and need a quick answer stick your requests in here. Keep things simple and only reply if you know the correct answer.
Don't know German? look here
Moderator: Scirocco Register
teenspirit7
Postby teenspirit7 » Mon Nov 16, 2015 2:34 pm
Looking for part number and/or links/advice on where to buy.
MK2 Rear view mirror.
craigwalton
Re: MK2 Rear view mirror
Postby craigwalton » Mon Nov 16, 2015 4:30 pm
Very difficult to find. I had the same issue:
http://sciroccoregister.co.uk/carforum/viewtopic.php?f=6&t=19260&p=133826#p133826
For a lot of original ones, the plastic housing seems to have perished. If you're lucky enough to find one on eBay/Amazon, get them to check the plastic housing is still solid but you'll probably be £50-£70. An alternative is to use a Golf Cabrio mirror, which has the same "metal plate bonded to windscreen" mechanism, even though the mirror itself is slightly different. They're maybe slightly easier to source. See this post http://sciroccoregister.co.uk/carforum/viewtopic.php?t=15740.
In the meantime, if you feel safer driving with a mirror, it may be worth get a cheap £5 stick-on mirror as it might take a while to find a proper one!
Perhaps ask nicely in the "Parts Wanted" section.
Blueshark
Postby Blueshark » Mon Nov 16, 2015 7:52 pm
Here is the part number to the interior mirror:
447857511 01C
Hard to come by.
If you find one watch for the next issues:
1. very expensive, 2. dried out and full off cracks, 3. lame swivel so it will not stay in place.
Joost
Rocco2
Postby Rocco2 » Wed Mar 15, 2017 2:49 pm
Is there chance to find replacement mirror glass for the side mirrors?
Plastics are ok but the glass itself has started peeling from the edges.
Rocco goes turbo
Postby the edmundator » Wed Mar 15, 2017 9:32 pm
Someone else here bought a Passat part which is still available new and is more-or-less exactly the same.
1980 Mk1 GLi
1982 Mk1 GTI (pending project)
Rocco2
Postby Rocco2 » Wed Mar 15, 2017 9:35 pm
Alright, I will look into it.
Thanks.
Rocco goes turbo
Postby the edmundator » Wed Mar 15, 2017 9:39 pm
Sorry, not Passat, Audi 200.
44785751101c is the Audi part number... same as VW.
It might also be worth checking if Porsche 924 mirrors are the same, as Porsche have very good classic car parts support (the 924 part number is 477 857 511 which is not massively different and it certainly looks similar in the photos I've seen).
1980 Mk1 GLi
Rocco2
Postby Rocco2 » Sun Mar 19, 2017 8:05 am
So I manage to get new mirror glass parts, aftermarket ones (costed 4€ a piece :D ). They have double sided tape on the other side...
How the originals are installed?
How I can remove the original mirror glass?
Rocco goes turbo
Postby the edmundator » Sun Mar 19, 2017 6:02 pm
By breaking the mirror. It's not designed to come apart.
1980 Mk1 GLi
DannyH
Postby DannyH » Sun Mar 19, 2017 6:35 pm
Actually it's easier to tape it on top of the old one if it has double sided tape?
Danny
Rocco2
Postby Rocco2 » Sun Mar 19, 2017 7:01 pm
Yeah I also thought that just taping new ones on top would be the easiest way.
So no way to remove old ones, ok good to know.
Rocco goes turbo
DannyH
Postby DannyH » Sun Mar 19, 2017 7:24 pm
There is a way to remove them but if i remember right it's more trouble than it's worth.
Danny
Rocco2
Postby Rocco2 » Sun Mar 19, 2017 9:47 pm
Ok, another question regarding the side mirrors :D
My friend got a pair on newer ones for his rocco. How to replace those with ones on right now? He can't seem to find a way to bolt them on.
Rocco goes turbo
steve bain
Postby steve bain » Sun Mar 19, 2017 11:22 pm
i fitted a mk3 or mk4 golf one, cant remember which but it fits perfect and looks almost identical, cost £4 from the scrappy
ThomasD
Postby ThomasD » Sun Mar 19, 2017 11:54 pm
Mk3 Golf one in mine - no complaints. Way better than the original which kept falling off!
Mk2 Scirocco Storm
Mk3 Golf GTI VR6
Return to “Part number queries and NOW translation queries too”
Who is online
Users browsing this forum: CommonCrawl [Bot] and 0 guests
