Stereo code
Stereo code
I have a sony xr-M510 stereo that i want to put in my scirocco. The wiring is all fine but when i connect it all up it says 'code' Reading through the manual it says to use the remote to enter: sound-mode-att-open/close. I have tried this but it dosent work i even changed the battery in the remote. Any ideas anyone?
Re: Stereo code
If you don't have the code, you probably need to take it somewhere that can recode radios. I had this done for a Blaupunkt unit (about 7 years ago now, mind) and it cost about a tenner.
Re: Stereo code
do you have the correct code for it? if not, PM me the serial number - i might be able to help
