Please could someone help me I need to find where the ignition switched wire is for the stereo and are losing the will to live could someone pls point me in the right direction .
Adam
Where and how to find switched ignition power supply to p
Re: Where and how to find switched ignition power supply to p
The Scirocco was fitted at the factory with a permanent live not a switched live for the stereo. You can take a switched live from the blower switch above the stereo, that only works with the ignition on.
Thanks for the quick response can sleep now then tackle again in the morning
