Just been surfing around and came across this site.
http://www.qh.com/shop/product/start
Its fairly concise and QH products are pretty decent. I used to work in retail car spares and never had any probs with them.
A list of what they cover:
Accessories Boot/ Load Bay
Axle Mounting/ Steering/ Wheels Mounting/Fastening
Steering Links (control arm, trailing link, diagonal arm)
Ball Joint
Mounting, suspension strut
Fasteners
Wheel Bearing
Belt Drive Tensioner Pulley
Timing Belt
Timing Belt Set
V-Belt
Body Gas Springs
Gas Springs
Brake System Brake Caliper Parts
Brake Hoses
Brake Light Switch
Control Levers/ Cables
Brake Disc
Brake Pad Set
Brake Parts/ Accessories
Brake Drum
Brake Lining/ Shoe
Drum Brake Parts
Wheel Cylinders
Clutch/ Parts Repair Kit, clutch complete
Cooling System Radiator /Parts
Sender Unit, coolant temperature
Thermostat
Gasket, water pump
Water Pump
Electrics Alternator
Sender Units/ Sensors
Light Switch/ Lever
Sensors
Starter
Engine Vacuum Pump
Air Filter/ Housing
Engine Electrics
Engine Mounting Bracket
Tensioner Pulley
Timing Belt
Timing Belt Set
Seals, coolant circuit
Oil Filter
Oil Pressure Switch/ Sender Unit/ Valve
Exhaust System Assembly Kit
Clamps
Gaskets
Exhaust Pipes
Exhaust System, complete
Silencer
Filters Air Filter
Fuel Filter
Hydraulic Filter
Oil Filter
Fuel Supply System Fuel Filter/-housing
Fuel Pump
Interior Equipment Boot
Maintenance Service Parts Additional Repairs
Service Intervals
Spark/ Glow Ignition Ignition Cable/ Connectors
Ignition Distributor/ Parts
Steering Bellow/Seals
Filter, power steering
Steering Gear/ Pump
Steering Joints
Parts, tie rod assy.
Tie Rod Assembly
Suspension Coil Springs
Ride Height Control/ Suspension Hydraulics
Shock Absorber
Assembly Parts
Suspension Strut Bearing
Towbar/ Parts Parts
Transmission Mounting
Wheel Drive Bellow
Quinton Hazell Online Catalogue
The most useful content will be added to the FAQ
