87 Black GTX
Moderator: Scirocco Register
scrappy1382
Re: 87 Black GTX
Post by scrappy1382 » Tue Sep 12, 2017 7:13 pm
steve bain wrote:I do like your wheels.....
gives it that rough and ready look :-)
Scirocco Shane
84 Havanna Brown Storm - 8-)
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun Sep 17, 2017 1:45 pm
This is all back together now and its back to the cranking but not firing problem
Messed about with some flip paint
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun Oct 15, 2017 1:20 pm
Still chipping away at this, lots of small jobs to do before all the big stuff can be done for final
The results of trying out the flip paint
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun Nov 12, 2017 10:57 am
We have a runner
Re: 87 Black GTX
Post by mark1gls » Mon Nov 13, 2017 10:17 am
Well done :-D
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Mon Nov 13, 2017 5:40 pm
Had a look through my pics and found one of the engine code, its not an ABF but an ACE which is an audi variant of the 9a corrado short block 2l
Re: 87 Black GTX
Post by mr.brown » Mon Nov 13, 2017 6:43 pm
BlackGTX wrote:Had a look through my pics and found one of the engine code, its not an ABF but an ACE which is an audi variant of the 9a corrado short block 2l
Slightly better than the 9A as it has the same head as an ABF (rather than the KR). Slightly worse than an ABF due to milder cams.
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Mon Nov 13, 2017 7:19 pm
Thats good news,
we looked at the cams and its stamped 027 which i think is kr so it should produce 150 according to online talk
Tuning beyond that is probably on the expensive side so will have to wait a year or two
scrappy1382
Re: 87 Black GTX
Post by scrappy1382 » Mon Nov 13, 2017 10:53 pm
kieran, focus on getting her all road legal 1st buddy, enjoy the driving her around for a while then see what plans arise. you have been at this for quite a while now, looking forward to cruising around with ya again.
Scirocco Shane
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun Nov 19, 2017 1:08 pm
Quick pic from a while back of the new tank before it went in
Foamed the top with sound deadening foam
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun Nov 19, 2017 1:10 pm
Replaced the oil cooler too. Need to do the south african cluch kit too really whilt theres more room in the bay
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun Dec 03, 2017 7:52 pm
Still working in this, the kr loom is out as it was 10" to long at the bulk head which isnt a huge problem but the rocco 16v loom is obviously a perfect fit
Currently runing lumpy with a low idle and a max of 3k on the revs so will look that over
On a plus i drove it out and back in the garage for the first time the other day
Re: 87 Black GTX
Post by james butler » Sun Dec 03, 2017 8:23 pm
BlackGTX wrote:still chipping away at this, got some clearance issues at the mo
dizzy fouls, should be able to rotate it but there are only 2 positions to bolt it in
had to use a flat brake res cap as the induction arm sits on it and the coolent hose wants to go through it at the mo
you could use a remote reservoir like on crusty and shanes car
i actually have a load of the rubber reservior pipework left over if your interested?
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun Dec 03, 2017 9:27 pm
Ive got 2 options im looking at, 9" servo with 16v res and normal dizzy or std 8v res no fluid sensor and a 45° dizzy for clearance
Im trying to keep it looking as factory as possible
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun Jan 28, 2018 10:09 am
Phone doesnt seem to pick up the lower notes so sounds tappy
Got this running on a kr loom, not resolved the brake res / dizzy situation yet
