88 scala project.
essextom
Re: 88 scala project.
Post by essextom »
So cars off the road for a few minor mods.
Started with a number plate relocation so the front valance is being smoothed over. I plastic welded the holes over and I’m using bumper filler which should be a bit more flexible than the usual stuff.
essextom
Post by essextom »
Next up is new boost pipes and a bit of and engine bay tidy up. then maybe a few more interesting unusual bits to add
essextom
Post by essextom »
Just been going through and deleting the defunct photobollox pictures and i realise ive no info on my rear lights.
these are the rear lights i custom made for the car. they are made from the original lights with the lenses removed and then i fabricated new lenses from acrylic. heres a link to the build guide- https://dreadnoughtcustoms.co.uk/pages/diy-mod-guides
essextom
Post by essextom »
Next mod, e30 headlights and mk1 grille.
essextom
Post by essextom »
front end has changed slightly.
essextom
Post by essextom »
not updated this recently, this is what ive been up to-
removed painted and refitted gearbox
removed brake bar assembly and in the process of fitting a bias pedal box and re making the brake lines
smoothed and painted inlet manifold and cam cover
re covered the engine wiring loom
fitted new aluminium top fil rad, just need to make a custom fan cowling
need to remake the fuel lines to make them a bit neater
the recaros are also going in for a retrim shortly and im thinking about changing the boot build to make it more exciting.
thats about it for now, ill update photo's once items are finished
