Hi everyone!
I'm trying to replace the rear wiper motor on my MkII but am having trouble removing the old one. The wiring block attached to the motor won't fit through the little hole in the tailgate where the cable goes through.
I'd be grateful for any tips.
Cheers!
Rear wiper motor replacement help!
Re: Rear wiper motor replacement help!
I cut the tang between the two slots. Could get the connector block out then, no issues at all, been like this now for 5 years
Mark
Alpine White
VW Scirocco GT2 (1991)
Membership Number 1296
Alpine White
Or get a special tool to remove the connectors from the block - ebay, Amazon all sell these or similar
https://www.amazon.co.uk/Terminal-Extra ... ay&sr=8-30
Problem solved! I simply removed the connectors from the block by yanking them out. Thanks to both of you for your input. It's much appreciated!
