hi all
i’m after some stiffer springs and want to find out the spring rate of my weitec hicon gt coilvers.
i know the fronts as it’s written on the front springs, 60n per mm, but i can’t find out the rears as it’s rubbed off the springs! any photos i have from back when are blurry, and weitec wont tell me what the rate is as i’m not buying the new springs from them.
i could corner weigh the car but i’ve already busted one set of bathroom scales!
does anyone know what the rear spring rate is? thanks
weitec hicon gt coilovers.. rear spring rate?
- essextom
Re: weitec hicon gt coilovers.. rear spring rate?
ive got hicon tx and can check spring rate tomorrow on mine if not rubbed off, not sure if they would be the same though.
My Weitec HIcon GT rear springs have 200 - 50 stamped on them if this means anything to you.
I've now fitted 400lb springs up front and 325lb springs rear and it's fantastic :)
