one way you can do it but adjusting is a bit more difficult is to put a plank of wood up against the bottom of the wheel and vertically against the arch of the bodywork.
then take a ruler and measure the gap between the top of the wheel and the plank.
or buy a large set of these https://www.machinemart.co.uk/p/trend-5 ... ngle-rule/
i have a small set but the large one could be placed against the wheel and the floor to do the same thing (although getting to the adjuster nuts on the suspension is a bit difficult).
Hi everyone, just thought I'd introduce myself and my shedrocco
Re: Hi everyone, just thought I'd introduce myself and my shedrocco
Ive had a change of heart and I'll be listing the car for sale next week. Ill put it on ebay and ill list it on the forum aswell.
Got those wasps ready?
A bit to sheddy for casual use?
- unknownmale
Way too fancy for me, just axle stands on the wishbones on a level surface and a digital level on the hub facejames butler wrote:one way you can do it but adjusting is a bit more difficult is to put a plank of wood up against the bottom of the wheel and vertically against the arch of the bodywork.
Would be interesting to know how close I got on a hunter.
to be fair as long as the cambers even you shouldnt have any real issues albeit handling may suffer.
if done right the car should track nice and true.
if you have uneven camber even if you have perfect tracking the car will have a tendancy to pull to one side and the steering at an angle to go in a straight line.
