when i refit the windows should i use some sort of gloop?
years ago i used a silicone sealant just to be sure but having just spent an age getting the stuff off i feel it may not be the right thing to use again. is there some sort of non setting stuff? or just i just use the rubber and clean surfaces? rubbers all in good nick.
same question for door and boot seals too
window seal gloop?
Re: window seal gloop?
I've never done this myself, but I have a VW Scirocco service bulletin which says the following:
"To prevent leaks, windscreens, rear windows, and side windows are being sealed with window sealing compound during production.
After removal and installation or when changing a window glass the body channel and the window channel in the window seal must be sealed all the way around.
The sealing is carried out using window sealing compound D 001 007. "
There is a figure which shows some sealant being used between the body and the window seal and between the glass and the window seal. Unfortunately I'm not sure what compound D 001 007 is - silicone or something else...
Mk2 Scirocco Storm
Mk3 Golf GTI VR6
Mk3 Golf GTI VR6
when auto windscreens put my windscreen in they used some kind of black sealant that never goes off.
looks a lot like roof and gutter sealant.
maybe its worth popping down vw and asking what D 001 007 is?
well, the arbomast autograde turned up today - £7ish off ebay. I'll be hopefully fitting glass this weekend so will let you know....
