Would the fog lights on my mk1 be a dealer fit option or fitted by a previous owner? I can never remember when they became a requirement.
I'm tidying up the dash loom ready to refit it, and the radio and fog light wiring is awful! Scotchlok and wires twisted together and taped up
mk1 rear fogs
Re: mk1 rear fogs
Rear fog light became standard in 1980, previously was an optional factory or dealer fit.
Re: mk1 rear fogs
My 1978 GLS came without a fog light.
When my brother had the car before me he went out and fitted one
Re: mk1 rear fogs
Quote from MOT manual:
"This inspection applies to the one rear fog lamp which is required to be fitted to the centre or offside of vehicles first used on or after 1 April 1980"
So technically, if yours is registered before this, you can get away without one.
GT Matt
1988 Mk2 GTX
1988 Mk2 GTX
Re: mk1 rear fogs
I removed the fog light on my '78 as I think it looks a lot cleaner and as mentioned is not legally required, every MOT I've had though they have popped off to the office to check the regulations
Re: mk1 rear fogs
Have you just removed the light or does the switch has to be removed as well?
Re: mk1 rear fogs
I've removed the switch as well and just have one of the factory blanking plates in the space.mark1gls wrote:Have you just removed the light or does the switch has to be removed as well?
I'm a bit unsure on the legal requirements I think if the light is fitted on the car it has to be working but if you have a switch but no light fitted thats ok.
Re: mk1 rear fogs
as its looking Luke I'm gonna be bumperless for a while due to dwindling funds, my rear fogs are going to be removed. But living I'm the Cotswold water park, fogs are needed, so I'm going to convert the o/s reverse light to become my fog light. Can't decide between fitting a red high power led bulb, or cut the back away and fit a square led fog light unit into the existing lens
