this may sound like an odd question but if yo needed to disconnect the ball joint with the wishbone do you pop the ball joint out of the hub OR do you undo the 3 bolts that secure the ball joint to the wishbone?
it struck me as maybe being easier to undo the 3 little screws or am i going mad?
and yes i am that bored!
popping ball joints
Re: popping ball joints
Pop it out of the hub to save you from disturbing the wheel alignment.
'89 Sapphire Scala Inj.
Member No. 1455
Member No. 1455
- essextom
Pop it out, double check the hub/ballpoint bolt, mine had corroded a fair amount.
