need a high pressure fuel filter?
just so happens halfords do a metal canister filter that has normal 8mm hose tails!
so you can just push on some 8mm rubber hose with some jubilee clips.
fuel filter
Re: fuel filter
Not sure how much that filter is but you can buy metal filters from car parts 4less or Euro car parts, listed under mk3 golf, 2.0L.
£7.43 (with discount code) for a good quality MANN filter.
Re: fuel filter
only problem with the mk3 filter is the connections are made for plastic pipe quick connections and not for rubber hose unlike the above.
with a halfords trade card the filter was £8
Re: fuel filter
Ok I see, not really looked into it as the mk3 filter does not fit any of my cars.
