Hi chaps.
Im considering adding spacers to the rear wheels on Redrum to bring them out a bit, but will need longer wheel bolts. Halfrauds are being their usual unhelpful selves, so I wondered if people knew where to get them and what measurements (if any) I will need when ordering them? The wheels are 15in alloys and not standard.
Thanks.
G.
Longer wheel bolts. Info needed please...
- Ryan
Re: Longer wheel bolts. Info needed please...
Hi Glen.
I recently got put a pair of 6mm spacers on the front.
Previous bolt threads were about 28mm got some new ones that are 35mm off of that there
You need to add however much the spacer width is to the thread length over stock - not rocket science.
I found this a good intro for the basic things to know...
http://www.performancealloys.com/nuts_bolts.asp
- Ryan
Thread pitch = 12x1.5mm
Also try to get them with the same bolt head measurement - mine came as 19mm so I've now got different sized heads as the locing nuts - not too much of a pain now - as I bought a new socket which has both on - but if you get the choice, stick with what you've got on the front - probably 17mm.
Got mine from here
http://myworld.ebay.co.uk/pcs-uk
Got mine from here
Euro perfomrance have always been helpful when I;ve used them. Think their bolts were about £1.50 each.
Aftermarket wheel specialists will sell you longer bolts (and spacers). Make sure you get the correct type....angled or curved....for the wheels.
email me on sciroccosteve@hotmail.co.uk. i have a full set (12 maybe 16) of 10mm longer than standard with 4 locking wheel nuts that are 10mm longer too (4). i bought them off here a while back but have since changed my mind. ideal for 10mm spacers obviously and for alloys. yours for £20 posted. steve
Glen,
PM us your address, maybe able to help out
got bolts on Ferocio which are aftermarket VW thread but 40-50mm Long IIRC
All I did was grind down to suit at front discs but the rear as I remember were straight swaps with 10mm spacers
Brass007
Brass007
Royalrocket A.K.A Ferocio owned by an 8 year old! With RAG and Dr Dub Storm for company!!!
- Redrum
Thanks lads. Will send out emails / pms today.
My Photo Albums: http://s47.photobucket.com/home/gplace/allalbums
