15x8 Help/ advice please
Moderator: Scirocco Register
Chris M GT
Post by Chris M GT » Fri Jan 19, 2018 6:53 pm
Hi,
I've been looking at putting 15x8 et25 on the rear of my Mk2 with 195/45 tyres, can someone confirm these will fit without arch mods and without scrubbing most importantly!!! I was going to go 7x15 et25 but it won't give the look i'm after.
Any help much appreciated.
unknownmale
Re: 15x8 Help/ advice please
Post by unknownmale » Sat Jan 20, 2018 3:53 pm
I have 15" 7j et25 on the rear with 195/45/15 on and i've just ordered a 10mm spacer as they're just a bit too tucked in. So I think you'll be fine on the arch and should have enough space to the spring.
- David
BlackGTX
Post by BlackGTX » Sat Jan 20, 2018 8:42 pm
Looking at the banded steels i noticed this
15x7 et25 15x8 et 20 15x9 et15
Chris M GT
Post by Chris M GT » Sat Jan 20, 2018 8:50 pm
BlackGTX wrote:Looking at the banded steels i noticed this
Those sizes definitely seem about right then, thanks a a lot for the info, I'll post pictures when it's done :)
mr.brown
Post by mr.brown » Sun Jan 21, 2018 10:48 am
If you're local to Surrey, I've got 15x8 ET0 with 195/45 that you could try. If that fits then ET25 will be no problem
GBB
Post by GBB » Thu Mar 07, 2019 4:57 pm
Did they fit in the end?
