Factory sunroof postion
Moderator: Scirocco Register
1981rocco
Post by 1981rocco » Mon Apr 15, 2019 7:32 am
Could anyone get me some measurements for the factory sunroof position?
I'm restoring a gtx an want to weld in the original sunroof.
Verstuurd vanaf mijn SM-G960F met Tapatalk
Blueshark
Re: Factory sunroof postion
Post by Blueshark » Mon Apr 15, 2019 8:54 pm
Are you going to make the hole yourself or do yo have a roof with the original hole in it you are going to place ?.
Joost
1981rocco
Post by 1981rocco » Mon Apr 15, 2019 9:17 pm
I have a golf2 roofskin with sunroof.
Plan is to weld in just the rim for the sunroof and then the assembly underneath the roof.
Blueshark
Post by Blueshark » Tue Apr 16, 2019 8:05 pm
Good luck wit that job then, is going to be hell of a job to get the sv=ceet metal in without warping the rest of the roof.
Those measurements you will probably only find in a Body repair shop because manuals just have maintenance in them.
I have an English manual but nothing on placement measures in there.
So best is to get a Scirocco with the roof and measure one on one at the spot.
Joost
Eagle1
Post by Eagle1 » Wed Apr 17, 2019 7:39 pm
It might pay to find someone close so you can take the measurements yourself.
Post by GTXTRA » Thu Apr 18, 2019 7:23 am
