MK2 rear arch liners
Moderator: Scirocco Register
NebToast
Post by NebToast » Sat Feb 09, 2019 10:00 am
Anyone know where to get a passenger side rear arch liner? Would a MK1 golf fit?
Re: MK2 rear arch liners
Post by mark1gls » Sat Feb 09, 2019 10:15 am
VW did not fit a liner on the rear passengers side just the drivers side to stop dirt etc getting stuck in by the pipes.
The Mk1 Golf and cabriolet did not have a liner either.
Post by james butler » Mon Feb 11, 2019 3:03 am
what you can do is make a chicken wire mould to fit the arch in the shape of a liner then remove it and cover it in fibreglass.
once set you have a liner you can fit.
Blueshark
Post by Blueshark » Mon Feb 11, 2019 1:28 pm
What do you need an arch liner for, there can only get dirt behind, stay wet and rust the car quicker.
Just dry it well with an electric heated fan and seal it with sealant and cover in bodyshoot or under protection or wat even you call it.
Just make sure all the seals and cracks are dry before sealing them off.
Joost
NebToast
Post by NebToast » Mon Feb 11, 2019 1:32 pm
Ah interesting, might look into a chicken wire affair if I get time in the summer then
