Fuel pick up.
Hadders
Fuel pick up.
Post by Hadders »
Could someone please post a picture of the orientation of the fuel lines on the pick up pump. Under the rear seat 1.8 8v scala.
Re: Fuel pick up.
Is your Scala carb or fuel injection?
If carb you can blow down the fuel line either return or send and see which pipe petrol or air comes out of, this will not work on fuel injection cars.
The fuel lines near the tank are very similar looking have you mixed them up or not sure which metal pipe on the fuel sender/lift pump is which?
Hadders
Re: Fuel pick up.
Post by Hadders »
Sorted thanks seems i had the pipes the wrong way round. What an idiot.
Re: Fuel pick up.
Glad it's sorted, easily done as they do look the same.
