Plastic pipe
Plastic pipe
There's a short bit of plastic pipe between the accumulator and end of metal fuel line running under the car. Is this correct? And where can I get a replacement? It really narrow, 8mm maybe?
- MRMENDER
Re: Plastic pipe
You will be lucky to get another clear plastic one quickly. Its best you replace it with any good quality, unleaded petrol compatible hose. Any motor factor should keep a handy sized length in stock.
I bought a reel (10M) off ebay for around £15
Re: Plastic pipe
It's actually black so wondering if it's the poly worsit pipe. Can I replace it with braided over rubber and jubilee clips or are the pressures to high? The accumulator is mounted solid so maybe just extend the new hard lines all the way to it? Or does it still wobble?!
Re: Plastic pipe
http://www.partsbase.org/vw/scirocco-sc ... fuel-pipe/
Is it no2 in the picture, part number 171201218C?
If so they sell it here.
http://www.golfmk1.co.uk/Items.php?grou ... ES&cat=ALL
or here
http://www.classic-vw.co.uk/mk1-golf-fu ... 7527-p.asp
I think VW heritage sell it as well but there website seem to be down tonight.
or here
Re: Plastic pipe
You try crazyquiffs? I got stainless fuel pump bracket and a braided hose or two of them from accumulator.
