Kjet fuel line diameter
I need to replace the 2 fuel lines that run from front to back , pump to filter. Is this 8mm OD? Or 8mm ID? Everyone just says 8mm lines and wanted to check. Also does anyone know what length I need? Cheers
Re: Kjet fuel line diameter
Or would I be better to fit braided hose slipped over the ends of about 30mm of thr old pipe and jubileed on?
