Problem putting fuel in
Moderator: Scirocco Register
Jimbog
Post by Jimbog » Sat Dec 01, 2018 3:09 pm
Hi All,
I have a 93 K reg mk2 GT2 and every time I put fuel in at the petrol station I cannot keep the pump lever on the fuel nozzle from cutting off. I have to stand there and keep squeezing the lever adding fuel bit by bit. I have tried positioning the nozzle in different positions etc but I cannot get fuel to continuously flow into the tank. As far as i can see the filler neck is in good shape. Is there a pressure release valve or something somewhere that may be blocked?
Jimbo
BlackGTX
Re: Problem putting fuel in
Post by BlackGTX » Sat Dec 01, 2018 4:27 pm
Think that is a sign of a blocked breather
Post by james butler » Sat Dec 01, 2018 11:11 pm
there is a half inch pipe that joins the filler neck aperture to the top of the tank to allow it to breathe, as black gtx says theres a good chance its blocked so the escaping air cannot get out other than back up the filler pipe which will cause it to trigger.
Jimbog
Post by Jimbog » Sun Dec 02, 2018 11:26 am
Ok thanks guys. I’ll take a look.
Blueshark
Post by Blueshark » Sun Dec 02, 2018 9:00 pm
https://volkswagen.7zap.com/en/rdw/scir ... 201-66000/
Check the hose number 10, could be block.
Joost
Jimbog
Post by Jimbog » Sun Dec 02, 2018 11:58 pm
Thanks Joost
