Drove home the other day - no issues.
Went to start her yesterday - zero action from the ignition.
Battery seems fine, as blower & lights will work but not even a click when I turn the key.
Thoughts?
GT2 Dead!
- scrumpyone
Re: GT2 Dead!
Sounds like either the ignition barrel or the starter motor, I would start with the starter motor and go from there
Sent from my SM-G965F using Tapatalk
- scrumpyone
Re: GT2 Dead!
Thanks Nugg will do.
Dave
Register No:1110
'79 MK1 GLS (R.I.P.)
'91 MK2 GT2 (alive & kicking)
Register No:1110
Re: GT2 Dead!
check the battery connections especially where the live feed to the fuse box is attached, i had random cutting out and non starts from that wire being loose.
also check your earth wire to the gearbox is good to the chassis and battery
- scrumpyone
Re: GT2 Dead!
It turned out to be a flat battery. Had enough juice for some electrics but not enough to turn over.
Dave
Register No:1110
Register No:1110
