to Replace the bulb in the headlight switch you need to pop the switch out of the dash board and unclip it from the bunch plug.
The bulb is in the bunch plug and is removed from behind where the wires are.
I suggest disconnecting the battery before messing with the wires to prevent shorting anything.
Remove the brown and black blue cables then Using the plastic tang that’s part of the bulb holder at the back twist until the bulb holder unclips and withdraws from the back of the connector.
Headlight switch bulb
