Mk2 Headlight Wiring
- Site Admin
Hey guys,
Got a little bit of a strange one from what I can work out. My headlights, the drivers side is fine however the passenger side seems to turn the dip beam on when the sidelight should come on and stay on when you switch the headlights on.
I'm guessing something has been wired wrong as it's defiantly Been messed around with from looking at it.
Does anyone have a wiring diagram for the loom? Would be great if ya do
- scrappy1382
Re: Mk2 Headlight Wiring
Scirocco Shane
84 Havanna Brown Storm -
- Site Admin
Better than what I've got currently! Thanks
I have just found a Haynes manual so now I'm got to go hunting lol
Sent from my iPad using Tapatalk
- scrappy1382
Scirocco Shane
- Site Admin
I've seen a few posts about it but all the pictures have been expired, does it actually make a big difference?
I was personally thinking what was the point as the car pretty much will never be driven at night lol
- scrappy1382
in comparison to how the original wiring is then yes, a massive difference,
my opinion , not enough to actually see comfortably where yo are going on a unlit road at night.
i chose the hid route but the kit i got had beam correctors and were brilliant by far.
http://www.ebay.co.uk/itm/New-XENON-AC- ... SwOyJX7M0r
many members may advise you to try different routes as their not supposed to be on our style cars, but i have never been pulled over, and drove my blue storm loads at night.
Scirocco Shane
- scrappy1382
or these, which i have in the monza derv. actually not that bad either.
http://www.ebay.co.uk/itm/Nighteye-9000 ... SwImRYV00R
Scirocco Shane
- Site Admin
Nice one thanks mate, to be honest I think I'm going to look at fixing the current ones and see how I get on and then think about the upgrade
The main problem with the VW standard set up is the full 12v current runs from the battery, through the fuse box to the switch, through the switch and then onto the lights, it's a long way to travel on old wiring and common to have a switch burn out or worse a burn/smoke from the wires behind the dash.
If you replay the headlights you reduce the load running through the switch etc as the power is now coming straight from the battery to the headlights.
There is a dim dip resistor fitted to the headlights which dims your main headlight bulbs (H4) when you turn the side lights on (little 4w bulbs), it's positioned underneath the front slam panel, size of a pack of Polos with 2 yellow wires going to it, you need to remove this if relay headlights, just unplug it and tape up the wires. This may also be why you have different things happening on the lights if some one has already relayed the headlights?
Can you post up a picture of what you have on the car?
- Site Admin
Hmm yeah I see what you mean, I'll post a picture on Saturday hopefully as annoyingly I didn't take one. I do recall that's half the cables aren't actually connected on the drivers side but that side works and the passenger side has some connectors which aren't plugged in but I have no idea where they are from lol
It could be someone has relayed your headlights already?
Is there an extra power cable coming from the battery?
- Site Admin
To be honest I haven't a clue, I tried it last thing the other day when I was having an argument with the sunroof lol I'll take a look and see what I can work out and get back to you
Cheers for your help so far mate
- Site Admin
Hey mark,
Right I took a look tonight and with the aid of a multi meter actually managed to work out what wires are what so we are all sorted!! Wohoo
I do have one question which are the 2 cables in the image below. They come through the headlight loom on the drivers side but have been cut. There is nothing obvious that they go to, they are not to do with the light that I can work out and also aren't the fog lights as I've found them.
The red and white has a permanent voltage of 2 or 6 volts (it's only one of them but I can't remember which one it was)
Any ideas?
Any ideas?
Is that wire white with just 1 red stripe and the other wire white with 1 blue stripe?
I'll have a look at my Mk1 golf tonight as I'm currently using my Mk1 Scirocco and that seems to have a slightly different set up as i have a white and 2 red stripe wire going to the headlight socket?
- Site Admin
Hmm yeah it's defiantly not the headlight, there is the red and white and the blue and white both one stripe.
I have at the weekend done the delay upgrade to it so all is working well now but I haven't a clue what these 2 are for?
