meta alarm fitting
meta alarm fitting
I am going to retro fit a meta alarm that I took out of my old Audi a4 before I scrapped it into my scirocco. Now there are 2 wires on the alarm ,dark blue and a white wire that are supposed to be wired into the fuel pump to act as an immobilizer but my Rocco is a carb with a mechanical pump. Can I somehow wire these wires into the ignition/distributer/ coil to have the same effect? If so what wires can I tap into??? Thanks.
Re: meta alarm fitting
Anyone know????
