rad fan switch
rad fan switch
I,ve got a 1990 GT, replaced rad fan switch but doesn't cut in till very hot.(assuming temp gauge is right)
The old switch had two pins, is this correct?
The connecter that fits on it, would fit a 3 pin..
If the switch is correct, (bought new 2 pin) then maybe my temp sender is reading hotter than it should..?!
red light comes on but the fan kicks in later than that and then only for a few seconds....
Re: rad fan switch
What does the gauge read when moving and driving normally, 1/2 way?
I would try a new temperature gauge sender to see if it reads different.
- scrumpyone
Re: rad fan switch
On my GT2 it's a 3 pin switch - not sure for your GT but I would guess the same.
Dave
Register No:1110
'79 MK1 GLS (R.I.P.)
'91 MK2 GT2 (alive & kicking)
Register No:1110
Re: rad fan switch
Mine is a GT2 now Ive checked...
so will try 3 pin, and maybe new temp sender as well.
My gauge quickly reads 2/3, at that point thermostat opens. Normally reads about 2/3 to 3/4s..
Two of you from Somerset which is were I got the car....It had the wrong temp gauge in to begin with hardly read at quarter.
Would not be surprised if fan switch was wrong perhaps too. Its had a long history, engine off a golf we think?
- scrumpyone
Re: rad fan switch
Where about in Somerset did you get her?chrisdevon wrote: Two of you from Somerset which is were I got the car....
I bought mine from a small garage in Beaminster, Dorset almost 21 years ago. It was for sale on behalf of the original owner who lived in Yeovil.
Dave
Register No:1110
Register No:1110
Re: rad fan switch
What sort of sensor do you have and what colour is it?
1 like this?
http://www.ebay.co.uk/itm/VW-MK2-Golf-G ... 0782882259
or 1 like this?
http://www.ebay.co.uk/itm/Water-Coolant ... Sw44BYKw58
1 like this?
or 1 like this?
Re: rad fan switch
Sorted it was temp sender, the top link above type but black..
wish I had tried that first, I bought a new black one only in December, but now wonder if it was faulty all along.(did move quite quickly)
So I now have two spare good 2 pin rad switches, I've fitted the three pin, though looking at the connector it fits the three pins but not sure all three are wired up. Still it works and comes on about 2/3 temp, now my temp sender is showing me more accurate temp.
I bought the car from village near Bath, Green, two lady owners, the 2nd the Niece of the 1st owner.
Re: rad fan switch
Glad it sorted.
I'm just up the A303 near Yeovil and not far from the Haynes Motor Museum which is worth a visit but no Scirocco in there, so only just over an hour from Exeter.
Perhaps with scumpyone we will have to arrange a South West meet sometime or perhaps a convoy if you are going up to the national meet in August?
Re: rad fan switch
No plans to go to national meet yet, but may do. But yes would be good to get the sciroccos together. Also I will let you know next heading up the A303, I am overdue a trip to Haynes also..
Re: rad fan switch
At Haynes they have built a new front and fitted in a big new cafe which is very nice and if you are just passing you don't have pay the admission fee to get in the cafe but will still need to pay to get into the bits with the cars.
See if we can sort out a day and place to meet when the weather gets a bit warmer.
- scrumpyone
Re: rad fan switch
Sounds like a plan.
Dave
Register No:1110
Register No:1110
