New Heater Blower Fitting
Moderator: Scirocco Register
teenspirit7
Post by teenspirit7 » Sat Jan 16, 2016 1:49 pm
Hi,
I've come a bit stuck trying to replace my heater blower.
I'm planning to take it out via the bonnet (rain tray). To remove the front wiper motor do I need to first remove the wiper arms? I've removed the nuts but it won't budge.
I've been trying to follow eefy's guide but just can't remove the motor.
Images to jog your memories
https://imgur.com/a/l3DZH
Thanks for reading.
eefy
Re: New Heater Blower Fitting
Post by eefy » Sat Jan 16, 2016 2:15 pm
yeah you'll need to wiper arms, once the bolts off it should pull off, the wiper arm is connected with a spline joint, this might just be bumped up and may need some persuasion. Some light tapping with a hammer may help. Once there off the whole wiper motor needs to be removed, the raintray on the passenger side is widened to allow this.
the heater motor then needs to be split in two, its a bit fiddle to get it our in 2 parts but it will some out again on the passenger side.
Goodluck
Heath
teenspirit7
Post by teenspirit7 » Sat Jan 16, 2016 6:57 pm
Thanks for the help. Managed to get it fixed! Now I'll actually be able to see out of the windscreen.
eefy
Post by eefy » Tue Jan 19, 2016 9:05 am
Glad its all sorted :)
C 20 CCO
Post by C 20 CCO » Mon Feb 05, 2018 10:56 am
Glad you fixed it..................................
It may help to put a tiny amount of copper grease on the spline before refitting the wiper arms; not too much but enough to help make it easier to remove next time. The splines get furred up over a long period of time and can be difficult to remove unless you have a set a arm pullers.
kind regards,
Dave.
To be old and wise......
In the garage : 2005 Volvo V50 2L D in brilliant blue metallic.
2011 Mazda2 Tamura in vibrant ebony metallic.
Prized possession- 1991 GT11 in Pearl green metallic.
rosie
Post by rosie » Thu Sep 17, 2020 4:38 pm
I've also been following eefy's guide today and have got as far as taking out the old motor (god knows how I'm going to get the new one back in - plenty of swearing so far!)
My new motor is apparently the right one, but the wiring is different. As per the photo
The original motor has a pair of yellow wires on one connector and a brown wire on the other.
The new motor, on the right in the second photo, has a plug with two prongs - one attached to a red wire and the other to a brown wire. (sorry the picture doesn't show the wires very well)
Presumably I attach my yellow spade connector to one of the prongs and the brown connector to the other but please can someone tell me which way round they go?
Thanks so much.
GT_II
Post by GT_II » Thu Sep 17, 2020 6:27 pm
Brown is VW's colour code for earth (negative) and red for live (positive). Yellow here would be the switched live, which would be full battery voltage at maximum fan speed or a fraction of battery voltage at lower fan speeds. So brown to brown, yellow to red should do it.
rosie
Post by rosie » Thu Sep 17, 2020 7:13 pm
Awesome. Thanks for the help.
