electric window switches
- Site Admin
I'm a little confused regarding the windows switches on mine.
Basically they don't fit?
are they from a different car? or are the holes to big?
basically what do i need to replace to make it work
Re: electric window switches
The switches in your picture were the later dealer fitted ones. They are similar to the later MK2 Golfs, Corrados and Passats of the same era. The original Scirocco ones are a rocker type that don't illuminate (sorry don't have a picture to hand).
- Site Admin
when you say later mate do you mean later roccos or later models? ie corrado ect.
Im guessing i am needing some of the rocker ones then as these are quite a bit off fitting even though they work lol
The later model Sciroccos were fitted with electric window switches like the ones you have.
i think that there is 2 different surrounds for the switches?
seem to remember having a similar problem and i changed the surround.
Danny
- Site Admin
Well that would make sense, mine 1992 mate.ianaudia4 wrote:The later model Sciroccos were fitted with electric window switches like the ones you have.
hmm interesting... anyone else know this is true? and even better if someone has some :)DannyH wrote:i think that there is 2 different surrounds for the switches?
or glue them into the hole with some pu sealant (sikaflex, tigerseal etc)
- Site Admin
That's joost,
I'll have a look for some
And that's how they were mate but still the massive gap and looks awful
- Blueshark
There are surround for the switches, single for passenger and double for drivers side but not very easy to come by.Jack92 wrote:That's joost,
I do have the switches new, for info PM me.
Joost
might be easier to change your doorcard?
just to make sure i'm on the right track it is that the hole in the card is too big for the surround to fit?
Dan
Dan
Danny
- Site Admin
Yes you are mate, but it doesn't look like its been cut bigger hence why I presumed its the wrong switchDannyH wrote:might be easier to change your doorcard?
Dan
probably not the switch but the surround my switches fitted fine in the bigger surround or you could get a door card with a smaller hole?
Danny
- Site Admin
yeah that did cross my mind but whats going to be more expensive thats the question. Im off the see jim tomorrow so ill see what bits i find from the bandit and who knows may be lucky
These are the factory fit switches that I have in my Storm. The dealers were fitting a different sort (like the original picture) on the last of the MK2's.Blueshark wrote:These are the switches you need.
https://www.busdepot.com/media/catalog/ ... 959855.jpg
Joost
