Repairing my speedo clocks is getting to be like a can of worms...ARRR
I've had to fix them several times, just trying to find a decent set that work!
Got to replace the odometer gears as mine stopped working, so got a donor set.
While I'm at it, thought i'd check why the green led (indicator blinker) doesn't work on mine.
Tested the PCB track to the LED with multimeter, and it appears to be a broken connection in one of the tracks!
Can't for the life of me find where though, PCB looks ok overall.
Is there any way to repair these ? Or does anyone have a really good PCB for a Scala Carb speedo....
Getting kind of desperate!
Thanks.
Chris
Speedo clocks - Broken PCB!!
- bluestreak56
Re: Speedo clocks - Broken PCB!!
There was a company that fixed them but they went bust.christhemann wrote:Repairing my speedo clocks is getting to be like a can of worms...ARRR
Thanks.
Chris
I believe it can be done although how difficult is another question - Pete may know - I'd suggest replacing the PCB or the clocks altogether .. I have about 4 sets myself from fixing bits.
Chris - do you have the diagram showing you the test points on the PCB? If not pm me your email address and when I get a moment I will scan something in for you.bluestreak56 wrote:There was a company that fixed them but they went bust.christhemann wrote:Repairing my speedo clocks is getting to be like a can of worms...ARRR
Thanks.
Chris
Are you sure that the LED itself is working and has not given up? I haven't had the indicator LED fail yet but the main beam indicator one seems to be prone to failure.
I haven't fixed a flexible PCB, but Tempest has. It can be fiddly and care is needed with the soldering iron. Alternatively you may find that VW still does new ones. You will need the VW part number/s off the clocks - 533 ... or maybe 191 ... or both, in order for VW to locate the right one. There is no VW part number written or stuck on the actual PCB itself.
Rohan, if I say 'Sender' to you .......
- bluestreak56
I know I know! Im very very sorry but Im going to bring it along with an extra something to make up for it at the Volksfest if thats ok?PeteGLi wrote:
Cheers for that.
Pete - Testing diagram would be handy thanks. I've traced the track to the indicator led, the LED itself does work also as I've checked it seperately.
The track to the LED works only intermittently if I press on a certain part of the track!
Getting pretty desperate as I've got the clocks apart and out of the car. (its my only car so need to get them in soon!)
1989 Helios Blue Scala
can you just solder a wire on to replace the broken track? scrape the insulation off, the dab a spot of flux on, and it should be fine. did it on my bro's R21 when i stuck a screwdriver through the pcb
