shift light circuit testing
My shift light has gone kaput. I think this is down to the relay 171919091 in the fusebox. Is there a way to test this with a multimeter? Thanks.
- unknownmale
Re: shift light circuit testing
Take it out and apply a power and ground to the control side and check for continuity with a multimeter on the load side of the relay, you should also here it clicking when 12v is applied to the control side.
- David
Cheers I will try this!
