Rubbing/ Grinding Sound When Taking Off
Whenever I first take off, there's a slight rubbing noise that makes it sound like fork being rubbed against a plate without the high pitched noises. I'm pretty sure its a bearing. Any help would be appreciated!
- haddock_n_chips
Re: Rubbing/ Grinding Sound When Taking Off
Lift each corner up in turn and rotate the wheel to see if you can replicate it.
